Anybody know the shaft diameter for the stepper motor
Results 1 to 3 of 3
Thread: Anybody know the shaft diameter for the stepper motor
    Banned
    May 2008
    Default Anybody know the shaft diameter for the stepper motor
    I would like to try some other brand of stepper motor and want to know the shaft diameter for both stepper motors,
    Thanks a lot, Jeff
    Member number40Fan's Avatar
    Nov 2019
    Default Re: Anybody know the shaft diameter for the stepper motor
    I bet I could find a picture of the part number on the motor while I had things apart. I'll check tomorrow.
    Curious why you want to change them out though.
    Banned
    May 2008
    Quote Originally Posted by number40Fan View Post
    I bought 2 of these 3 phase servo stepper driver and corresponding 1130 oz stepper with encoder and brake.
    Drive work with 220v
    Shaft diameter is 14mm
    Just wanted to know in advance if shaft dia were the same, will try to replace original motors in a couple of weeks if I have enough free time.
    Thanks for the reply
    Attached Thumbnails Attached Thumbnails Anybody know the shaft diameter for the stepper motor-capture-png
    Attached Files Attached Files
