can you post your threading code ?
I am in contact with tormach for help with this, but I was wondering if any of you came across this before? All my threads look like barbed fittings. The start end thread form looks more or less correct, but the back side looks like a different degree. Using iscar lay down inserts, tried a shars one too. same results from conversational or fusion. It did this on earlier versions of path pilot when I got the machine, but I didn't need threading at the moment and assumed user error. My thought is maybe the timing is not calibrated correctly? I verified z travel to be accurate to a known good indicator over 1.5".
- Build Thread- Threading issue
- threading issue/question
- Problem- sherline/deskcnc threading issue
- Need Help!- Threading Issue with SL80
- Problem- Roll threading 2-56 look issue
-Jon
instagram @hermit.shed
(External Threading G-code generated: Mon Mar 30 15:55:07 2020 <v1>)
(PathPilot Version: 2.4.3)
(Description = externalThreading)
(Material = Aluminum : -any-)
(Units = G20 inches)
(Work Offset = G54)
(Tool Number = 6)
(Tool Description = od groove thread)
(Tool Type = rtp_part)
(Tool Orientation = 6)
(Tool Radius = 0.0158)
(Spindle RPM = 400.0)
(Z Start Location = 0.0000)
(Z End Location = -0.3800)
(Thread Specification = 1/2-13)
(Thread Direction = Right Hand)
(Inside Diameter = 0.4041)
(Outside Diameter = 0.4985)
(Taper [incl. lead in/out] = 0.0000)
(Thread Length = 0.3800)
(Pitch = 0.0769 inches/thread)
(Threads per inch = 13.00)
(Depth of Cut = 0.0403)
(Thread Lead = 0.2)
(Tool Clearance = 0.03)
(Number of passes = 6)
(Spring passes = 1)
(Tool on X+ side)
(Note: for 2 NPT External Thread)
(Pipe OD = 2.375)
( for use with OD Turn and Chamfer)
(Effective Thread Length = 0.7565)
( use as the distance between z_start and z_end in Chamfer)
( use an angle of 1.78 degrees)
(----- Start of G-code -----)
(<cv1>)
G7 (Dia. Mode)
G18 (XZ Plane)
G90 (Absolute Distance Mode)
G40 (Turn Cutter Compensation Off)
G20 (units in inches)
G54 (Work Offset)
G30 Z #5422 (Park Tool)
T0606
G97 (RPM Mode On, CSS Off)
S 400
M8 (Coolant ON)
M3 (Spindle ON, Forward)
G0 X 0.5585
G0 Z 0.2000
G76 P 0.0769 Z -0.3800 I -0.0600 J 0.0403 R 2 K 0.0944 Q 30 D 0.0000 H 1
G0 X 0.5585 Z 0.2000
M9 (Coolant OFF)
M5 (Spindle OFF)
(</cv1>)
(----- End of Thread -----)
M30 (End of Program)
-Jon
did some more experimenting today. I swapped holders out to a dorian triangle on edge type and got good threads. I checked both holders and the tip of the insert is within a few thousandths of each other so I don't think it's a tool center height issue. I used the same program to run 5/8-11. part on top is the laydown iscar, bottom part is the on edge.
-Jon
Are you using a holder with a threading insert or some other sort of other insert type? External threading inserts usually look like this:
https://tormach.com/11ela60-threadin...-lh-37288.html
I think I figured it out. The inserts I bought off ebay and I believe they are not the part number on the package. I believe they are npt. once I swapped to different brand insert the threads worked out.
-Jon
Can we get a pic of the orginal insert?
Also, on the Slant, I will program three spring passes (H3).
