Tool length weirdness
Results 1 to 9 of 9
Thread: Tool length weirdness
    Nov 2016
    Default Tool length weirdness
    Ok, I'm pulling my hair out over here. Long proven program all the sudden falling short of the part Z0 on an ID chamfer with a small boring bar. Touched the tool off again to update the table, nothing. Reset the tool, nothing. Here's where it gets weird, I can G0 Z0 both my ref tool and the boring bar BEFORE the program and they hit the same spot. During the program, the boring bar falls .111ish short of the part face (Z0).
    Zero changes to the program from when it was running hundreds of parts perfectly, and all done in PP conversational. Update from 2.1.9 --> 2.2.2 hoping that might fix it, but no change.
    T01 - Face to Z0
    T01 - OD Chamfer
    T07 - Drill bore .3125'
    T05 - ID Chamfer
    T08 - Tap
    Thoughts and ideas are appreciated.
    S.
    Mar 2008
    Default Re: Tool length weirdness
    Is it simply possible that the part is slipping in the collet/chuck?
    Nov 2016
    Definitely not slipping.
    Mar 2008
    Quote Originally Posted by ScottDW View Post
    Do you have any wear offsets in the tool table? Conversational will apply then, manual won’t unless you specify such
    Nov 2016
    No wear offsets for that tool, or the reference tool. I call T0505 as a habit, anyways.
    Feb 2007
    New Zealand
    Hi Scott - have you got any further?
    I am not quite following you sequence prior to error, but does it fit a stepper or stepper brake coupling slipping?
    Or please explain in more detail.
    Cliff
  7. #7
    Nov 2016
    Cliff,
    Yes, I got the issue resolved. The g-code was no different to the eye, but when I ran it through a g-code interpreter it was showing strange characters that I had not put into the code. After lots of calls with people way smarter than me, what we determined is a newer version of PP than the one it was written in didn't agree the old code. The new post interpreted some NL and CR where there was none and barfed right in front of that op. It's still confusing to me how it happened.
    I reprogrammed that op fully from the new version of PP and it worked like a charm.
    TLR - New PP post didn't like old PP code.
  8. #8
    Member mountaindew's Avatar
    Nov 2007
    earth
    Cliff,
    Interesting!
    Will need to keep an eye on this issue. I have no less then a dozen PP updates over the years and wondered how generic of code was created by conversational setups and how well they run from update to update. To date I have never had this issue with a cam post.
  9. #9
    Feb 2007
    New Zealand
    Cliff,
    Thanks for the reply - I hope that was an isolated incident and not going to be a regular problem. Cliff
