Turret for the Slant Pro - Pros / Cons
Results 1 to 2 of 2
Thread: Turret for the Slant Pro - Pros / Cons
    Oct 2010
    Default Turret for the Slant Pro - Pros / Cons
    Looking for anyone who added a turret to their Slant Pro after they had been using just gang tooling. Basically, was it worth it? I keep going back and forth on should I add the ATC or not. Sure would be nice to have some standard tools loaded at all times. I watched Cliffs video on how the turret gets you close but you will still have to dial in the tools each run if you want accuracy. I'm okay with that, seems like it would be better than a full setup. I know I'll have to take the enclosure off but that's okay, I had been needing to take it off anyway to do a better job of caulking and sealing the damn colander.
    So.... Post up your thoughts. Right now I'm leaning towards adding the turret as the first of my 2019 upgrades plan.
    Thanks,
    Awall
    Awall - The Body Armor Dude
    CoolCNCStuff_ on Instagram - CoolCNCStuff.com
    Default Re: Turret for the Slant Pro - Pros / Cons
    Wow, too bad nobody ever commented on this. Did you ever upgrade to the Turret?
