Hummm, I've had my Slant Pro for a little over a year and have never had that issue. What version of PathPilot are your running? Also, have you reached out to Tormach? PM me if you want to discuss over the phone.
I've read the manual and searched but haven't found how to save the tool offsets. I go through all the work setting offsets, but after I shut down the machine then restart it they are all gone. How can save them/
- Fauna 21T tool offsets and work offsets
- Newbie- Broke tool T1 - Need offsets remeasure. Knee mill. Ref tool F1/F2 question.
- Need Help!- TLO Tool Offsets Zeroed and Fixture Offsets Lost on Power Down DX-32 Torq-Cut 30
- Newbie- tool number disappear after power off
- Problem- 21iT: Using 2 offsets for 1 tool:Machine stops for tool change
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
Running 1.9.13. Have ordered 2.0.0 but it was shipped Pony Express and it seems the pony is union. Hopefully it will arrive sometime before the next ice age. Another problem I'm having is when coding a Z move for a turning operation, I get a error message that the programmed move exceeds the positive limit of the Z axis, then executes a G30 which PP has inserted into my code. Seems no matter how much I shorten the Z move I get the same error. I found I can get around it by hitting Alt X, then editing out the g30 move, after which the program runs to completion with the full Z move as coded..
