Fusion 360 / Tormach Slant Pro - Front mounted tooling, X axis positive or negative
Results 1 to 2 of 2
Thread: Fusion 360 / Tormach Slant Pro - Front mounted tooling, X axis positive or negative
    Dec 2011
    Default Fusion 360 / Tormach Slant Pro - Front mounted tooling, X axis positive or negative
    I have a new slant pro. I have my students manually program as well as use fusion 360. In fusion, with the front tooling, it shows everything in the positive direction in terms of the x axis. When I post process, using the Tormach post processor, it shows all the x values as negative. I have not yet run the machine as we are still off for the summer I am just trying to plan for September and as the students begin by manually g coding I need to determine what is happening on the x axis.
    Will they need to program x negative? ; If they are using front mounted tooling.
    Why, if fusion is showing it as X positive moves, is the post processor showing x negative?
    Many thanks
    Rodney
    Oct 2010
    Default Re: Fusion 360 / Tormach Slant Pro - Front mounted tooling, X axis positive or negati
    It's set in the turret number used when you set up the tools (even if you're not using a turret). See the post processor notes.
    "Turning post for Tormach PathPilot on Slant-PRO or RapidTurn. Use Turret 0 for Positional Turret, Turret 1 for QCTP on Front Post, Turret 2 for QCTP on Rear Post, Turret 3 for Gang Tooling on Front Post, Turret 4 for Gang Tooling on Rear Tool Post. Valid RapidTurn Turrets are 0/2/4."
    Awall - The Body Armor Dude
    CoolCNCStuff_ on Instagram - CoolCNCStuff.com
