Mist Collector Options
Results 1 to 4 of 4
Thread: Mist Collector Options
    Jun 2016
    Question Mist Collector Options
    Anyone can recommend good mist collector/filter for the enclosure, preferably so its easily mounted on that 4" opening they have on top of enclosure? I am aware of Mistaway but those are huge, way too large for the little Slant Pro.
    Dennis
    Jun 2016
    Default Re: Mist Collector Options
    Found Royal Filtermist products. Looks great, but 3-phase power is no go for even a smaller unit :-(
    Dennis
    Are you looking to control the mist collector with an M code? If not, a rotary phase converter makes your search much easier. You're going to be hard pressed to find small units, since machine shops don't really care about having compact machines.
    I'd be hesitant to try to mount anything on the sheet metal of the enclosure. Why not mount it on a floor stand or from the ceiling?
    Jan 2016
    Quote Originally Posted by coffeetek View Post
    Simply use a low cost 1 phase in / 3 phase out VFD to drive Royal's 3-phase motor. Depending on the motor power this could be as low as $100-200.
