Motor pulley diameter
Results 1 to 4 of 4
Thread: Motor pulley diameter
    Banned
    May 2008
    Default Motor pulley diameter
    If I machine a smaller pulley for the motor, will it affect the SFM or feed or the RPM DRO?
    The lathe comes with two pulleys and two choices in the menu, 5C high speed and low speed for the 6in chuck.
    I would like to have a bit more torque by making a smaller pulley, could this be a problem?
    Thanks for any input.
    Jeff
    Member tmarks11's Avatar
    Jul 2004
    Default Re: Motor pulley diameter
    Quote Originally Posted by jeffrey001 View Post
    Unless you figure how to update the PP configuration file, it will give you erroneous values for all of that. And it is quite possible that the lathe will not even run, but will error out because the encoder measured speed doesn't match the commanded speed.
    Tim
    Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
    Banned
    May 2008
    Quote Originally Posted by tmarks11 View Post
    Thanks a lot, that exactly what I wanted to know.
    Jeff
    Sep 2015
    Jeff
    I don’t think it will effect anything. The encoder is attached to the spindle not to the motor. The controller already allows for 2 motor pulley sizes. You just tell it whether you are using the small or large. Try it. I bet it works perfect. I have stalled my spindle and the motor controller did not send a message to the control. It did not stop feeding until I hit feed hold.
