Need Help!- Multi Start threads
Multi Start threads
Is it possible to do multi start threads on this machine?
I use fusion 360 and not having much luck and wanted to make sure its even possible. Similar Threads:
Re: Multi Start threads
I have no idea but, I would try to change the Z start with half the TPI for the second pass, again, I have no idea as I never tried this.
Jeff
if you can single point thread on your machine you would be able to do multistart threads
a two thread lead you would position the start point pitch/2
Jeffery
Would there be some calculation as to how far to start out the Z?
Rcs60
So I start the 1st thread at whatever is regular then the 2nd pass at pitch/2?
Or both pitch /2 but offset somehow?
the first tread would be normally how you set up your threading
second thread lead start would be previous start + 1/2 pitch
20 tpi thread 2 lead start
ex. first thread start at .100
second start would be .100+.[.100/2]=.150
most multi-lead threads are spec'ed out at the threads per inch so that a 1/2-20 thread would have 2-10tpi threads with the pitch the equivocal of a 20tpi thread
Thanks took me a minute to figure out.
Threads per inch / 2 then the pitch of that thread / 2 + start.
This is just something I'm messing with myself no real design going off.
Forum Rules
