Sherline Rotary Table on PCNC 1100
Results 1 to 4 of 4
Thread: Sherline Rotary Table on PCNC 1100
    Nov 2011
    Default Sherline Rotary Table on PCNC 1100
    So I am fairly new to CNC machining and about 2 years ago purchased a nice used PCNC 1100 that had been upgraded to a Series 3 machine with Path Pilot. I have some projects coming up that I need a rotary table for and didn't want to spend the $2500 for one from Tormach, and is overkill for the small parts I make, so I bought a Sherline CNC Rotary Table. I installed a Tormach NEMA23 stepper motor on it because the Sherline motor that came with mine was wire for Unipolar and wasn't happy with the Leadshine driver. Now the Sherline has a 72:1 gear ratio where as the Tormach uses a 90:1 gear ratio. The Sherline motor was 400 steps where as the Tormach motor is 200 steps There are no settings on the driver to make this work, or that's what Tormach now tells me. I guess my questions here are, has anyone here did this successfully and what did you do to make it work? The Sherline is a nice little rotary table and is the right size for my work. Thanks, Zach
    Attached Thumbnails Attached Thumbnails Sherline Rotary Table on PCNC 1100-thumbnail_20230201_194856_resized-jpg   Sherline Rotary Table on PCNC 1100-thumbnail_20230201_194900_resized-jpg   Sherline Rotary Table on PCNC 1100-thumbnail_20230201_202854_resized-jpg   Sherline Rotary Table on PCNC 1100-thumbnail_20230201_202944_resized-jpg
    Jun 2018
    on my feet
    Default Re: Sherline Rotary Table on PCNC 1100
    If your all wired up then you'll just need to modify the scale in your ini file . I had a sherline on one of my 440's , I'd give you the settings I used for but I lost them after having to do a reinstall of pathpilot .
    Nov 2011
    Yes I’m all wired up, I will look into the ini file, where do I find that at? Thanks.
    Jun 2018
    on my feet
    you need to go into the os and you'll find the ini in the folder home/pathpilot/configs
