Yes, there is a coin cell in the controller which needs to be replaced every few years. I think Tormach has a bulletin on it but it is pretty straightforward. Open the case and find the silver coin cell and replace. You will likely have to go into the bios to reset the clock but it should boot properly with a new battery, whose purpose btw is to retain the settings in memory. Good luck.
