Autoleveller on Tormach Pathpilot
Results 1 to 4 of 4
Thread: Autoleveller on Tormach Pathpilot
    Sep 2005
    Default Autoleveller on Tormach Pathpilot
    Has anyone here tried running the Autoleveller (www.autoleveller.co.uk)software on a Tormach with Pathpilot???
    I have used it with Mach3 on a Windows machine but not Linux. Not much of a Linux person so not really sure where to start.
    Thanks,
    Robert
    Nov 2013
    Default Re: Autoleveller on Tormach Pathpilot
    I use Autoleveller but with Mach4.
    Autoleveller does not operate on a machine, just modifies the Gcode file you present to the machine, so it should work equally well on any machine. Note that Autoleveller has a Linux
    setting to 'flavor' the code output.
    Craig
    Sep 2005
    Not sure I follow your response as Autoleveller does use the machine to probe the surface of the object. That file of data is then used to modify the original G-Code for the actually routing.
    Maybe my question should be: How does one use the Tormach with Pathpilot to create the probe date file?
    Thanks,
    Robert
    Nov 2013
    there are two versions of Autoleveller, the first version run a probe routine and effectively records those data points in the registers of your control software.
    The second and better version is called AE. When you open Autoleveller it will ask for the OGF (Original Graphics File). AE will asses the dimensional extents
    of the file and generate a PFG (Probe File Graphic). Run this file on the machine and it will probe in a rectangular grid and save the data to a file of your choice.
    Once complete that data is consumed by Autoleveller AN your OGF to produce a 'corrected' file.
    Download and install AutolevellerAE. Run Autoleveller and browse to the required graphics file. Use the features of Autoleveler to determine the number of probe points,
    the speed at which the probing is to occur, and the heights, namely the retract height and the lowest probe level. Thereafter Autolevevller will produce a Gcode probing file to run on your
    machine. The AE version will ask you to nominate a data file into which the received probe data is to go.
    Craig
