Does anyone use the Tormach 440 for 1018 cold rolled steel?
I’m buying a 440 but can find too many specs on people using it for 1018 CR. I make small parts from .75” x .50” stock and want to know if it can handle a DOC of .25 with a WOC of .375 using a 3/8x2" .020" 4FL 1/2" F/L *AlCrN* end mill from Garr tooling. Thanks in advance
Re: Does anyone use the Tormach 440 for 1018 cold rolled steel?
Is there a specific reason for that particular tool and those specific cut parameters? I know the 440 will handle 1018 because I've done it (makerspace machine) and that was back when I had NO clue what I was doing. I don't know that it has the power to handle that big of a cut though. I suppose it will depend a bit on your chip load.
