Spindle won't spin
Results 1 to 5 of 5
Thread: Spindle won't spin
    Mar 2013
    U.S.
    Default Spindle won't spin
    Mar 2013
    U.S.
    Default Re: Spindle won't spin
    Couldn't figure how to edit my post, so let me clarify a little, The machine is an 1100 series III and the VFD, (not the VFR), displays error code v5, I've searched for a list of the error codes and so far have found nothing. Might have to go to the Tormach website which I prefer to avoid. For this "Alter Kocher" it's anything but user friendly. More like user antagonistic.
    Jun 2005
    Quote Originally Posted by jttoner View Post
    If you think Tormach's site is bad, try some VFD sites.
    rS is a motor problem (disconnected, wrong motor, etc) on the Emerson Commander SK. (Br rS may be a brake resistor error).
    https://www.mroelectric.com/blog/com...sk-trip-codes/
    Mar 2013
    U.S.
    Got copy of the 1100 manual, went through the checklist, measured the voltages, and operated the key a few times. Everything checked out OK. So, just out of frustration I pressed the start button and it came back from the dead. Same under program control. Works fine.
    Member popspipes's Avatar
    Jun 2014
    It is good that you're back in the shop John!
    Switches from inactivity develop an insulating film sometimes on the contacts, my VFD speed potentiometer is doing this now as I rarely use it (varies in rpm).
    mike sr
Spindle won't spin
Spindle won't spin
