Engraving problems
Results 1 to 5 of 5
Thread: Engraving problems
    Default Engraving problems
    I'm trying to engrave large 2.5" letters with the pre-set TORMACH engraving fonts on my 770..
    But, the pre-set fonts will mill around the outside of each letter, and then around the inside of each letter, creating two lines.
    I don't want that.
    I would like only a single line for each letter, so I can use a ballnosed endmill down center of each letter.
    How do I correct this?
    I've tried every font, and they all use inside/outside dual lines for the lettering.
    HELP!!!!!
    Dec 2013
    Default Re: Engraving problems
    A font with a .shx extension is single line.
    Jim Dawson
    Sandy, Oregon, USA
    Member popspipes's Avatar
    Jun 2014
    You just need a single line font, there are a few. I use the one that came with Rhino, its good for part numbering etc. and I use some specialized ones as well. that I found on the web.
    Single-line fonts
    mike sr
    THANKS PopsPipes!!
    I installed STICKFONT V1.1 on my old, beat up laptop, and it worked great!
    Easy to install, and very easy & basic software to use.
    Saves your text right to G-code.
    Thanks a bunch!
    Jun 2014
    Youre welcome sir!
    I use single line for part numbers on small parts that I make.
    mike sr
Engraving problems
Engraving problems
