Spindle rpm fluctuating
Results 1 to 8 of 8
Thread: Spindle rpm fluctuating
    Member popspipes's Avatar
    Jun 2014
    Default Spindle rpm fluctuating
    I noticed that my spindle rpm has been fluctuating a 100 or so rpm in manual mode at various settings, curious as to why its doing this? I havent noticed it when running a program, it may be doing it there too.
    Im sure this problem has come up before but the search function isnt bringing anything up.
    thanks in advance for any insight on this..........
    mike sr
    Member nitewatchman's Avatar
    Oct 2011
    Birmingham, Alabama
    Likely that the speed control poteniometer windings are dirty. A spritz of contact cleaner inside the back case while turning the knob may set it right.
    Quote Originally Posted by popspipes View Post
    Member mactec54's Avatar
    Jan 2005
    Default Re: Spindle rpm fluctuating
    This is normally caused by your 240v power supply or incorrect parameters set.
    Mactec54
    Jun 2014
    Thanks for the replies.
    I will try the contact cleaner thanks.
    mike sr
    Let me know how you make out. Mine has been doing this as well. Only noticed it after the most recent update but haven't gotten around to downgrading yet to see if the problem still exists. And I don't have an adjustment pot to clean so that's not an option for me.
    Jun 2014
    Quote Originally Posted by soofle616 View Post
    As near as I can tell its just a dirty pot, I ran the pot back and forth a few times and it seems to be better, I just need to get a can of contact cleaner and clean it up properly.
    mike sr
  7. #7
    Jan 2005
    Might be hard to get the contact cleaner to go inside the pot, to do any good, they are just a carbon pot, so this will happen until it won't work any more, you can add a remote wire wound pot to the remote control terminals then you would not need the VFD Drive Pot
    Mactec54
  8. #8
    Jun 2014
    It is a carbon pot, not a big deal as it only varies slightly in manual mode, havent noticed it when running a program.
    mike sr
