New Control for PCNC 1100 Series 3 upgrade to PathPilot
So I just bought a PCNC Series 3 that was still running Mach 3. The current control computer blue screens every few minutes, so I am looking to replace it and upgrade to PathPilot.
I've never run a Tormach, but I did a bunch of reading and I think this equipment I have listed below should work.
Could someone knowledgeable confirm this or point me in the right direction? The main concern is if the computer listed will work. Also let me know if there are other reasonable source for computers.
The computer will probably sit inside the stand where the current one is. I will be building an enclosure eventually, so the monitor will have to be mounted differently than currently. Let me know if there is better way to arrange things.
Re: New Control for PCNC 1100 Series 3 upgrade to PathPilot
I bought an early mill when they came out. When PP came out I did just what you suggest with no issues, still works to this day, get a wifi blue tooth usb dongle also.
The computer will probably sit inside the stand where the current one is. I will be building an enclosure eventually, so the monitor will have to be mounted differently than currently. Let me know if there is better way to arrange things.[/QUOTE]
