Originally Posted by
shred
Keep eliminating variables and testing. I strongly suggest to stop using model box points for your stock unless you absolutely need to. As soon as you change the stock, Fusion can reset cut depths and all sorts of things.
Is the part its cutting the right size? Cut some smaller scrap or even bits of wood or plastic to get faster answers if need be.
If the part is positioned in the wrong place in the stock but the right size, most likely your offsets are wrong. If it's the wrong size then other things like the tools are set wrong.
You should be able to see everything simulate in Fusion to see what its going to do. Define your stock to match what you have, hit the simulate button and see if it cuts how you think it should.
Once it simulates correctly in Fusion, take that code back to the machine and see what happens. If you have an edgefinder or even a small drill to pick out 0,0 instead of the probe, try that to eliminate the probe as the source of problems.. (set Z by touching off the stock with some paper or whatever other method you like.)
