Tormach 770MX Z Axis Clearance
Results 1 to 3 of 3
Thread: Tormach 770MX Z Axis Clearance
    Member Joz234's Avatar
    Jun 2021
    Default Tormach 770MX Z Axis Clearance
    I'm hoping to be able to fit a 12" tall part in the 770MX. Tormach sites the travel as 12.7, so given tool holding and tool height this makes it not seem possible. However, when I check their CAD model of the machine it appears that the distance from the bed to the bottom of the spindle is 15.075". And given that I doubt that the spindle nose can run all the way down into the bed, this seems to make sense. So the question is, could I machine the end of a 12" tall part in the 770MX?
    PS - The part is 12" tall after work holding.
    Default Re: Tormach 770MX Z Axis Clearance
    Would have to be someone with a 770 to answer completely so they could measure but as you noted, Z travel is not the same as Z clearance. Arguably, that is another specification that Tormach probably ought to list on the details page of each machine.
    Apr 2010
    Usa
    These pictures are on my 770M+. My fixture plate is .7” thick so add that to the tape readings. Id say 14.5” from table to spindle nose, 12.7 to face of a TTS set screw holder. Hope it’s some help
    Attached Thumbnails Attached Thumbnails Tormach 770MX Z Axis Clearance-c86a8f0c-3779-42b6-983d-533e028e472c-jpg   Tormach 770MX Z Axis Clearance-6372abc9-0cfa-4535-8988-5f62ac777e35-jpg   Tormach 770MX Z Axis Clearance-947da0fb-c7f6-425b-a88e-02c06dbeb31b-jpg
