When I try to reference my ATC , it rotates once and when the magnet is on the reed switch it starts to shake like it is not registering the sensor.
Sometimes this will go on for seconds, other times minutes before I get the error that says "ATC I/O failure"
My USB cable was damaged so I replaced it. (It arced through to the main body, cable got pinched somewhere)
I rebooted. Made sure the sensor is clean of any debris.
Would you recommend I update PathPilot because the software on my PC is old.
I found a loose connection at the 20 pin connector located above the servo motor of the ATC. The actual referencing pins were not making proper contact.
With that sorted, I now have another issue with an error "ATC Button - USB command Rejected"
So the cables and boards seems fine. All other commands get processed e.g. draw bar up and down, air blast on and off.
But to bring the tray in or to rotate one position, the ATC needs to reference itself first. By choosing any of the mentioned options, the ATC will do a full rotation and stop in the correct position (magnet on the reed switch) and then gives the error.
