Good score! I've always used the "official" Trico MD7. It is absurdly expensive but I use less than a gallon per year so it isn't a big expense. I normally start a job with higher flow to get the line filled and then dial coolant back to almost minimum. I usually leave the air flow at close to maximum. I never use flood so my solenoid valve is controlled by PP as though it is flood.
