Possibly some electrical noise or the limit switch cable is becoming intermittent or poor grounding or something of the sort.. I had a weird problem not too long ago where having a toolsetter just plugged in would cause BT30 spindle encoder errors. That's a bit different, but there isn't a lot of EMI-control in the 1100 so it might be worth checking the cable attachments and grounds are still solid.
