.010" egg-shaped while circle milling.
Results 1 to 4 of 4
Thread: .010" egg-shaped while circle milling.
    Default .010" egg-shaped while circle milling.
    Yikes!!
    I was circle-milling some bores yesterday, and they were coming out .010" egg-shaped.
    Y axis seems ok, as the bore was on size, but in X, I was getting +.010"
    Would this be a backlash issue? Or is it loose Gibs?
    Looks like it's time to tear the mill apart and tighten everything up.
    Nov 2012
    Default Re: .010" egg-shaped while circle milling.
    It could be loose gibs on Y, or backlash on X, or even perhaps some slop in the head/spindle. Sure hope it isn't the last one!
    Member machinehop5's Avatar
    Aug 2009
    ...is frontlash possible? Newton's Law of motice
    https://en.wikipedia.org/wiki/Newton%27s_laws_of_motion
    Aug 2010
    What material and size and how were you holding it? I've seen egging like that in plastic parts held in a vise. The vise was compounding a little bit of out-of-round. If there is any flex in the piece that could be contributing to seeing something egged more than expected, even in metals.
    Do you see the same amount on different size holes?
