Engraving tool style
Results 1 to 6 of 6
Thread: Engraving tool style
    Apr 2011
    Default Engraving tool style
    Hi All
    I saw this tool in an advert I received from Harvey tool, and thought is looked like it would leave a nice engraving tool path, but also thought it looked delicate as heck.
    I was just curious if anyone had any experience with this, or a similarly shaped tool?
    Terry
    Attached Thumbnails Attached Thumbnails Engraving tool style-harvey-engraver-jpg
    Aug 2009
    Default Re: Engraving tool style
    It will, and it probably is. I've not used that particular bit, but I have used bits that are typically used for PCB routing - and at small sizes, yes, they are quite delicate. A "V" style bit will be much tougher, but obviously leaves a different cut path.
    Aug 2013
    Most of my engraving is on mild steel. I tried the v-points but I found the Kyocera 1/32” 4-fl Bn stub endmills work the best for me and holds up longer than v-points.
    Plus the edges are not as pronounced and it takes less time de-burr/tumbling
    If you are using it on aluminum you may want to use v-points
    QUOTE=MFchief;2328650]Hi All
    Terry[/QUOTE]
    Member AUSTINMACHINING's Avatar
    Mar 2011
    Quote Originally Posted by MFchief View Post
    Hi All
    Terry
    Never used one, but if it's Harvey, probably works great.
    I use a .125 ball mill .005 deep. Looks real nice if you don't need tiny letters.
    Member mountaindew's Avatar
    Nov 2007
    earth
    Quote Originally Posted by AUSTINMACHINING View Post
    Good idea, I was just setting up some new parts and was using a v bit like mentioned above. This might be a little smoother looking for this model. Then again I might skip those ops and just do the lettering in conversational. I don't always like the text I can draw and import into cam models. But still experiment with small ball end mills - depth/path and font for something I like.
    Apr 2011
    I think I will give one a try, Harvey does have a good reputation, and I can get one for about $23.00 Only down side I see, other that delicacy, is they only cut one width so if you do a lot of different size engravings, it would add up quickly.
    Terry
