In sprut I use a standard 2d operation that follows an edge on the model. The example above shows the actual gear model, but I don't use that for the operation setups.
Quick summary.
1) I draw the gear blank model to the exact exterior root diameter of the gear. ( o.d. = (n+2)/p n= number of teeth)
2) I put a single line centered on axis on the surface of blank model. (in pic below)
3) Import model into sprut and position on 4th axis.
4) Defined a arbor saw as the cutter with the center of the outside cutting edge to be contact point on tool. (important) outside diameter set to the gear cutter diameter measured at bench and used for that gear.
5)Setup a standard 2d operation to follow the line on the gear blank model.
6) multiply the 2d operation tool path by axis "A" set the multiply number to the number of gear roots or teeth -1 on the model.
7) Compile code and check simulation. (shown in above post)
I found gear cutter diameters to vary slightly from cutter to cutter. And user needs to keep this in mind when setting up cam operations.
The manual method shown in post above, the cutter is centered and touched off . Then depth of cut (w) = 2.157/p is used for the cutter passes. Touching off the cutter would reduce error from cutter diameter differences that causes problems in cam setups.
I often draw threads and gear teeth because the models look better but I don't use them in cam operation setup. Thread milling, tension compression tapping are all simple operations to have preset for every type and size standard or custom in your cam software. Then user can load desired thread operation select model features, compile and your done. Super fast in cam software to do after you learn the process. And most cam software allows user defined ops. So complete sets of custom operations can be preset (drill pilot, drill size, tap) and saved for easy setup on all projects. This minimizes the time to setup and complete a complex model.
