Using a Tormach PCNC 1100M to machine Steel Moulds - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Using a Tormach PCNC 1100M to machine Steel Moulds
  1. #13
    Apr 2005
    Default Re: Using a Tormach PCNC 1100M to machine Steel Moulds
    Sounds like you own a shop making molds and needing molds for parts you make.
    Why not advertise to hire an employee already skilled with CNC programming and running a CNC mill? You might find an extremely competent and motivated person who can make it work for you. You can still follow along and learn about it but a person trained already would be invaluable to get the new process off the ground. Maybe even for a short term hire to get everything going.
    Could have them come in and make a mold from start to finish on Fusion 360 right in your shop including the Gcode and simulation of tool paths as an employment test.
    If you advertise for the job and can’t find the right person you would not be obligated to hire anyone. Might be nice to see who might be available.
  2. #14
    Member makesomerubber's Avatar
    May 2019
    Mumbai
    Thank you! It's reassuring to hear there is someone out there doing exactly what I intend to do with this machine. So exciting!
