Polycarbonate - off topic - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 21 of 21
Thread: Polycarbonate - off topic
  1. #13
    Member maker of things's Avatar
    Mar 2012
    Default Re: Polycarbonate - off topic
    I affixed rare earth magnets into bores in Delrin with 3m VHB tape with good success. The magnets are 1/2" dia about 1/8" thick. I cut squares of the tape and applied to magnet, then removed the backing and trimmed overhanging corners while trying to not touch the back of the tape. Both magnet and plastic were cleaned with alcohol in advance. The bores need not be tight for this application. Previous attempt with CA glue met with magnets releasing from plastic.
    tape https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    -Jon
  2. #14
    Apr 2011
    Thanks, if I can't get the glue to work, I could probably try the tape by sticking it to the plugs.
    Terry
  3. #15
    Feb 2018
    If the design allows, you could also, spot the bottom of the hole with a drill, just deep enough to leave a dimple for epoxy to sit in.
  4. #16
    Apr 2011
    On one half of the joints, I do have room for that, thanks.
    Terry
  5. #17
    Activation process mbarnett's Avatar
    Jan 2019
    You can press the magnets into a pocket and it will stay. I do this all the time. Just make a pocket about 0.005" smaller than the magnet. For instance I use 1/2" x .125 magnets and make a pocket of 0.495 x 0.130 deep and then press in the magnets. They do not fall out or cause cracks. I use 1/4" Poly. Just be sure to get your polarity correct because there is no taking it back without damaging the material.
    Mike
  6. #18
    Apr 2011
    Hi everyone.
    Just wanted to close out this thread that I started a while back.
    As usual life got in the way of finishing this project and I just wrapped it up today. I 3D printed the dust boot which took 16 hrs, and naturally the first one messed up and I had to re-do it.
    But, I did finish it up today, and to the point of the original post, I ended up sizing the magnet pockets in the polycarbonate arms, and the associated pockets in the printed PLA body for a light press fit. It seems to be working fine, but time will tell if cracks start to develop. Good news is, with our hobby/business, I still have the files, so if need be, I can make new parts pretty quickly.
    As you can see in the attached pic, the boot is held to the arms just by the magnets, in order to facilitate quick bit changes on the router.
    Thank;s to everyone for your suggestions and ideas.
    Terry
    Attached Thumbnails Attached Thumbnails Polycarbonate - off topic-router-dust-boot-jpg
  7. #19
    Member nitewatchman's Avatar
    Oct 2011
    Birmingham, Alabama
    Cool!
    Very nice looking job, what material was used to print the boot?
    Gary
    Quote Originally Posted by MFchief View Post
    Hi everyone.
    Terry
  8. #20
    Member popspipes's Avatar
    Jun 2014
    Attached ThumbnailsPolycarbonate - off topic-router-dust-boot-jpgVery professional looking job, congrats!!
    mike sr
  9. #21
    Apr 2011
    Thanks guys, appreciate it!
    Gary the boot just standard PLA, Jgaurora branded.
    Terry
