tormach limitation, or am I doing something wrong? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: tormach limitation, or am I doing something wrong?
  1. #41
    Member AUSTINMACHINING's Avatar
    Mar 2011
    Default Re: tormach limitation, or am I doing something wrong?
    FWIW,
    I bought the 3/4" Shank Haimer and ran directly in the R8 collet (no toolholder) with no issues staying within a few tenths . It was also nice to have the shorter gauge length.
  2. #42
    Dec 2008
    Switzerland
    Are you tightening the drawbar when using the Haimer? Do you need to tap the drawbar to release it?
    Step
  3. #43
    Activation process kevbo22's Avatar
    Jun 2018
    Quote Originally Posted by TurboStep View Post
    Step
    I do tighten the drawbar, but not so tight that I need to tap the drawbar to release the haimer out of the spindle.
  4. #44
    Did you put a collar on it so you could use it for height offset as well?
    Bob La Londe
    http://www.YumaBassMan.com
  5. #45
    Mar 2011
    Step
    I had pdb, so it was tightened like any tool holder.
    Shouldn't need to tap it if the r8 collet is lubed on the outside taper.
  6. #46
    Mar 2011
    Quote Originally Posted by Bob La Londe View Post
    No need for a collar, just the Haimer. Height was set on the tts granite block just like all tools.
  7. #47
    Member kstrauss's Avatar
    Apr 2013
    I think that his question was in relation to your usage of the Haimer to set Z-height of your stock. In my experience a tool with a 3/4-inch shank and flat top for the tool will vary slightly in Z location since the top of the tool rests on the R8 collet rather than on the spindle nose. I once tried to use a facemill with no TTS recess on the top. I eventually determined that the variation in tool length was of a result of how tightly the collet closed.
  8. #48
    Member Steve Seebold's Avatar
    Mar 2009
    USA and proud of it
    Quote Originally Posted by Snecx View Post
    I had this problem with Haimer and the TTS holder for it. The concentricity of the tip always go off by +/-0.01mm after a while, but not immediate like yours did.
    Unfortunately I don't have good news for you as I have pretty much given up on my Haimer. I use the Hallmark ITTP now and that has been a great piece of equipment.
    I hope you will find a solution for your Haimer soon.
    If your Haimer is off by .01mm, I wouldn’t even be concerned. That’s only .00039 inches. That’s less than half a thousandth of an inch. The machines aren’t even that accurate. If you need better accuracy than that, you probably bought the wrong machine.
  9. #49
    Jun 2018
    Hey everyone
    I recieved some goodies in the mail today. I got the new tool holder, but I also recieved a new generation model haimer and tool holder for that I purchased.
    I quickly went straight to calibrating the new generation model.... once calibrated, I took out of the spindle, put back in, and wouldn't you know it it repeats as it should!!!
    I did this probably 20 times to make sure I hadn't lost my mind. It repeated every time!!
    I WOULD LIKE TO THANK ALL OF YOU FOR TAKING THE TIME TO TRY AND HELP ME, ITS GREATLY APPRECIATED!
    I guess I had just got a bunk haimer?!? But my new generation model works...and so now I am happy!
  10. #50
    Member mountaindew's Avatar
    Nov 2007
    earth
    Awesome! The fun begins, I think you will find your Hamier a handy very precise tool. Quick tip the dial always turns clockwise moving into the probe tip. I keep that in mind and rarely break tips. After reading some posts here and doing some checking I decided to order a new 0.0001 indicator so I can get as fussy as everyone else. I spent an hour today aligning a 3 jaw chuck on my 4th axis. Fixtures and tools require a fair amount of time just to setup and use and or change out . And every little thing comes back to bite you somewhere big or small so it pays to check everything often. .
