Post Processor for PCNC1100 with SprutCam 9 and Mach3
Results 1 to 13 of 13
Thread: Post Processor for PCNC1100 with SprutCam 9 and Mach3
    Jan 2013
    Default Post Processor for PCNC1100 with SprutCam 9 and Mach3
    Can someone post the post processor for Sprutcam 9 for Mach3? I've searched Tormach support and it looks like they've removed everything except PP.
    You can also email it too me if that's easier. john.kittleson@hotmail.com
    Appreciate it!
    Member popspipes's Avatar
    Jun 2014
    Default Re: Post Processor for PCNC1100 with SprutCam 9 and Mach3
    I have used PP since inception, the same postprocessor works for Mach and PPilot......... Sprut 7 here.
    mike sr
    Member Steve Seebold's Avatar
    Mar 2009
    USA and proud of it
    I still use Mach III as well. If it ain’t broke, don’t fix it.
    By discontinuing support for Mach III, Tormach is telling us play my way or don’t bother me.
    Member kstrauss's Avatar
    Apr 2013
    Quote Originally Posted by Steve Seebold View Post
    Actually they are telling us that they want to provide customer support by selling only products that they can fix and even enhance. If you were to try PP you might actually like it. I'm curious though. What are your plans for when your existing control computer dies?
    Mar 2009
    USA and proud of it
    Quote Originally Posted by kstrauss View Post
    If/when that happens I’ll probably google Mach III and step up to whatever they have at that time.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Gold Member MichaelHenry's Avatar
    Jun 2006
    Chicago suburbs
    Good luck with that - Mach IV didn't have a very good reputation the last time I checked but that was a couple years ago,
  7. #7
    Aug 2009
    Mach only had one glitch for me, but the reason above is exactly why I ditched it and went with PP. A company reliant on a third party, is tied to the destiny of that third party.
    Juan
  8. #8
    What's in the Tormach controller that you can't run modern PC hardware?
  9. #9
    Apr 2013
    If you mean required to run Mach3 you need a parallel port. Also the OS previously supplied by Tormach was a stripped version of Win/XP which lacks drivers for much modern hardware. PP runs on most modern machines with a PCI slot for the interface card.
  10. #10
    So if his PC dies and he wants to stick with Mach 3 all he'd have to do is buy an ESS/UC300eth/similar device, then buy/build a new PC. Basically the same process as a PP controller. Of course you could always dual boot and run either software package.
  11. #11
    Apr 2013
    I don't believe that the version of Mach3 provided by Tormach was "unlocked". That is the user does not have the ability to change the configuration to use an ESS, UC300eth or similar device. Purchasing a full Mach3 licence and learning how to configure things would solve the problem. Upgrading to PP might be both cheaper and easier.
  12. #12
    Mar 2008
    You could get the unlock procedure by signing a disclaimer with Tormach. I and many others did that and Mach 3 became fully accessible.
  13. #13
    Dec 2008
    Switzerland
    Quote Originally Posted by Zetopan View Post
    Most of us just replaced the Tormach exe with the corresponding file from a standard Mach3 installation. The Tormach features remained but all the missing features re-appeared!
    Quote Originally Posted by CL_MotoTech View Post
    I tried the ESS a long time ago. Perhaps it's been improved since then but I wasn't impressed. I've seen videos recently that appear to show the similar issues to those I reported way back.
    I'd recommend PP over Mach3 with ESS to anyone. If anyone needs convincing here are some quotes from the man himself
    "I like the idea of the Smart Kool. Too bad it’s not compatible with Mach III."
    "I’d like to try Rapid Turn, but it’s not compatible with my MACH III, and as long as my MACH III still works, why change."
    Step
