Why do you not want the BT spindle with the power drawbar? The way the BT30 works, the power drawbar doesn't cause pullout, because you don't use TTS. The drawbar pulls directly against the BT taper. The pullout in TTS can happen because that shank is straight, and the R8 collet holds through clamping only, not pulling upwards like the BT30 does.
