No Path Pilot for Rapid Turn? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: No Path Pilot for Rapid Turn?
  1. #21
    Mar 2013
    U.S.
    Default Re: No Path Pilot for Rapid Turn?
    Quote Originally Posted by cncoperator View Post
    It's not just the super-duper new technology you're missing if you're not running the latest version. You can't help improve PP which would benefit all of us. For example if there is a problem or feature request with the most current version it makes sense for Tormach to look into it. If you're running an out of date version it's not a productive use of time to respond to an issue such as Path Pilot not supporting Rapid Turn that has already been addressed.
    In that case, if I have a problem I'll upgrade. At the moment PP 1.9.13 is running w/o issues.
  2. #22
    Oct 2012
    Quote Originally Posted by jttoner View Post
    In that case, if I have a problem I'll upgrade..
    Thank you.. As I understand it in another thread Kstrauss pointed out an obscure problem he was having that was fixed by an upgrade that was helped along by other users:
    Quote Originally Posted by kstrauss View Post
    I was playing with PP 2.0.0 since it is easy to install/re-install from the USB stick. After getting networking on my second Ethernet working manually I upgraded to the latest version of PP. On startup the newer version notices the extra NICs and prompts you to configure them. Problem solved thanks to everyone!
