In that case, if I have a problem I'll upgrade. At the moment PP 1.9.13 is running w/o issues.It's not just the super-duper new technology you're missing if you're not running the latest version. You can't help improve PP which would benefit all of us. For example if there is a problem or feature request with the most current version it makes sense for Tormach to look into it. If you're running an out of date version it's not a productive use of time to respond to an issue such as Path Pilot not supporting Rapid Turn that has already been addressed.
Thank you.. As I understand it in another thread Kstrauss pointed out an obscure problem he was having that was fixed by an upgrade that was helped along by other users:
I was playing with PP 2.0.0 since it is easy to install/re-install from the USB stick. After getting networking on my second Ethernet working manually I upgraded to the latest version of PP. On startup the newer version notices the extra NICs and prompts you to configure them. Problem solved thanks to everyone!
