1100 Y Axis Mod
Results 1 to 5 of 5
Thread: 1100 Y Axis Mod
    Registered selphb's Avatar
    Jan 2013
    Default 1100 Y Axis Mod
    I am looking to do the 1100 Y Axis mod to get a little more travel. I was told someone on this forum did the mod but can't find the thread. Any help would be appreciated.
    Registered popspipes's Avatar
    Jun 2014
    Default Re: 1100 Y Axis Mod
    1100 S3 here, 10+ inches Y, 19+ X, I think the Y involved moving the limit switch bracket a bit and resetting the new value in Pathpilot. The X was more involved, I remember that I didnt get the 20 inches I wanted but close...
    mike sr
    Jan 2013
    I am just looking to get the Y axis to 10" - 11" since allot of my customers seem to have projects in that size area.
    Jun 2014
    I didnt make it to 11, 10 + comes to mind, this was a few years ago and I dont really remember.
    I just checked it and its 10.125 Y and 19.25 X the max is a bit more than this.
    I had an 18" part and needed the X travel which I use quite a bit, the Y travel I needed once or twice but not often.
    mike sr
    Registered R.DesJardin's Avatar
    Aug 2008
    You never have enough travel. Today I needed X of 19.5", just can't do it on my machine, believe me I have tried. Also remember the distance the head/spindle centerline is from the rear column is a limiting factor for mega useable Y travel no matter what you do, I think you can only get to around 11".
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
1100 Y Axis Mod
1100 Y Axis Mod
