Need Help! Z axis stepper hot
Results 1 to 3 of 3
Thread: Z axis stepper hot
    Nov 2007
    Default Z axis stepper hot
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Z axis stepper hot
    for stepper motors 140 F is not very hot , its only 60C
    depending on which manufacturers data sheet you look at
    stepper motors can run at 70 to 80 C = 158 to 176 F
    its some thing that takes most people by surprise
    as they are usually more use to universal or servo motors that take more electrical power the more they are mechanically loaded
    with stepper motors the electrical power input is controlled by the stepper driver
    unless the driver reduces the motor current when the motor is idle
    the motor current stays the same even if its stalled
    John
    Nov 2007
    Thank you John! Appreciate the knowledgeable response.
Z axis stepper hot
Z axis stepper hot
