Solidworks CAM Post Processor for Mach 3 machines.
Results 1 to 7 of 7
Thread: Solidworks CAM Post Processor for Mach 3 machines.
    May 2008
    United Kingdom
    Default Solidworks CAM Post Processor for Mach 3 machines.
    Hello Tormach Owners,
    I have been searching for a post processor to allow me to use Solidworks CAM on my Mach 3 style PCNC 1100.
    Unfortunately I wasn't able to find anything suitable, so I have generated a version myself.
    This post is not fully tested but appears to generate code similar to that generated by Sprutcam.
    If anyone wishes to use this, please do so with caution.
    If you have any feedback I'd be happy to continue modifying the PP.
    Please note that this PP is for metric settings.
    Attached Files Attached Files
    Apr 2008
    Default Re: Solidworks CAM Post Processor for Mach 3 machines.
    Another option is to just upgrade to Pathpilot.
    https://www.tormach.com/store/index....es&portrelay=1
    May 2008
    United Kingdom
    True, but if you've got a pile of gcode files that run on the Mach 3 version, you might want the ability to continue using them, and I'm not sure whether this is the case if you upgrade to Path Pilot.
    Member popspipes's Avatar
    Jun 2014
    Quote Originally Posted by JTulley View Post
    any file that runs on Mach 3 will run on Pathpilot at least in my case that was never a problem
    mike sr
    May 2008
    United Kingdom
    Thanks, that's good to know.
    Member R.DesJardin's Avatar
    Aug 2008
    Quote Originally Posted by popspipes View Post
    Yep, I have files I coded years ago running Mach3 they work fine with PP when I use them now.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, ATC, 4th
  7. #7
    Member Pierre41's Avatar
    Apr 2020
    Good Morning, hope you can assist, I have a Mach 3 controller and Solidworks 2019, when I run the post it says its out of date, (The Licence)
    How do I go about obtaining the correct Post processor from SolidWorks 2019 to Mach 3
    Regards
    PIerre
