Problem Roundness accuracy on PCNC 1100 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Roundness accuracy on PCNC 1100
  1. #13
    Member Steve Seebold's Avatar
    Mar 2009
    USA and proud of it
    Default Re: Roundness accuracy on PCNC 1100
    My 8 year old 1100 will cut a circle round within.0015. If it needs to be closer than that, I don’t want the job.
    I make one part for my model boat hardware that needs to be .4995/.5000. That’s an outside diameter so I use a boring bar turned backwards and run the spindle in reverse.
    Other than that, I’ll pass.
  2. #14
    Member Don Clement's Avatar
    Jan 2007
    Running Springs, California USA
    Quote Originally Posted by Steve Seebold View Post
    I use a left hand boring bar in a boring head on my 1100 . On a hole the size of 1/2" diameter I drill first then bore undersize with the boring head then using a floating reamer holder ream to size.
    Don
    Insert left hand boring bar in boring head
    Roundness accuracy on PCNC 1100-boringhead-jpg
    Floating reamer holder.
    Roundness accuracy on PCNC 1100-img_7942web-jpg
