Can you physically feel any of those marks? If you drag your fingernail across the workpiece, can you feel any ridges?
Hi Folks,
Tormach 770, using the module 25mm endmill with tormach steel cutting inserts. I am working on dialing the program in for surface finish with poor results. I seem to have chatter maybe? it sounds ok when cutting, loud but no squealing. A-2 material, .060" DOC, .1" stepover, 1600 RPM, 18 IPM. Image attached, Thoughts?
Tim
Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
If you want a good surface finish, you would normally do a very shallow finish cut - typically no more than 0.005-0.010 DOC". You should likely also be feeding faster on the finish cut, to compensate for chip thinning. Assuming it's a 2-insert tool, 0.01" DOC, 0.1" WOC, I'd be running ~1300 RPM, 44 IPM. Are you using coolant? If not, you really should be. If so, what kind - flood? mist?
I find I get a really nice finish on most metals using HSM techniques - narrow WOC (usually ~0.05", and high speed). I would try 0.05" WOC, 1300 RPM, 60 IPM, using a Facing operation and only climb-cutting. This should give a good finish even with your 0.06" DOC. You MUST have coolant to do this.
Regards,
Ray L.
Yes you can for sure feel them. Its a 3 insert cutting tool. using flood coolant. i was hoping to reduce the cycle time, but i guess it beats hand lapping. 2d adaptive toolpath, ill give a finish pass a shot. thanks guys
