Originally Posted by
AMacGregor
I'm currently installing a slant pro and when making connections to the terminal blocks, the instructions suggest pushing a flat head screwdriver in to open it up then push the ferrule in to the corresponding hole. I've not had any luck with this - perhaps I'm using too much force but I tend to find that the terminal doesn't seem to spring back properly so it doesn't grab the ferrule. I had similar issues when setting up my 770 a few years ago; does anyone have any tips/advice on how it should be done?
