Just found out another clue to the problem: I wanted to use the x axis stepper driver to drive the z axis. When unplugging the z axis I noticed that the plug is burnt up. Looks like something shorted. Questions is: Is the short caused by the motor? If so, it would be a bad idea to plug it into the x axis driver. Could it be that just the driver is damaged? One of the lights is still on so it is at least partially working. Also, why wasn't there a fuse that blew... could have started a fire.
