Does the spindle heat up too much when running at top speed?
Does the snap latch for the spindle cover fasten securely, or does it sometimes open under vibration?
Are the way covers worn and letting chips/coolant in?
How worn is the drawbar in the spindle? This is marked as a "wear part" by Tormach, so you can get a replacement.
If it has ATC or PDB, are they properly adjusted, and are there signs of wear or cracking in tension points?
