Trying to do a simple PP Engrave and am getting "must use G0 or G1 with G53" not making sence to me
- Need Help!- I can not cut or engrave anything "softdog error"
- Need Help!- Has anyone ran into this error? Parasolid ® Kernel Interface Error: KI Error Code:58
- Need Help!- F-engrave
- Need Help!- 2D Engrave
- how to engrave
Yes Path Pilot Conversational
(Mill - Engrave Text G-code generated: Sun Mar 11 11:58:35 2018)
(PathPilot Version: 2.0.0)
(Description = 7/16 mark)
(Units = G20 inches)
(Work Offset = G53)
(Tool Number = 4)
(Tool Description = Drag Engraver)
(Tool Diameter = 0.0000 inches)
(Spindle RPM = 0)
(Text to engrave = 7/16)
(Font = /home/operator/gcode/engraving_fonts/BEBAS___.ttf)
(Font height = 0.5000)
(Scale = 0.000124007936508)
(X Base Location = 0.0000)
(Justification Setting = left)
(Y Base Location = 0.0000)
(Feed Rate = 60.00 inches/minute)
(Z Clear Location = 0.2500)
(Z Start Location = 0.0000)
(Z Depth of Cut = 0.1000)
(Ammend Serial Number = no)
(----- Start of G-code -----)
(<cv1>)
G17 G90 (XY Plane, Absolute Distance Mode)
G64 P 0.0050 Q 0.0000 (Path Blending)
(font: /home/operator/gcode/engraving_fonts/BEBAS___.ttf)
(text: 7*16)
#1=0.250000 (SafeHeight)
#2=0.100000 (Depth of Cut)
#3=0.000124 (XY Scale)
#4=60.000000 (Feed)
#5=0.000000 (X offset)
#6=0.000000 (Y offset)
#7=0.000000 (Z offset)
(Fill Line Scale = 24)
(Fill = 0)
G17 (set current plane to XY)
G90 (set Absolute Distance Mode)
G20 (set units to inches)
G53 (set current work offset)
G00 G30 (move to preset G30)
T 4 M6 G43 H 4
M5 (0 RPM. turn off spindle)
G00 X [#5] Y [#6]
G00 Z [#1+#7]
(start of symbol 7)
(starting X offset: 0)
G00 Z [#1+#7]
G00 X [1841*#3+#5] Y [3651*#3+#6] (moveto)
G01 Z [0-#2+#7] F#4
G01 X [1841*#3+#5] Y [3098*#3+#6] (lineto)
G01 X [1071*#3+#5] Y [3*#3+#6] (lineto)
G01 X [532*#3+#5] Y [3*#3+#6] (lineto)
G01 X [1303*#3+#5] Y [3098*#3+#6] (lineto)
G01 X [189*#3+#5] Y [3098*#3+#6] (lineto)
G01 X [189*#3+#5] Y [3651*#3+#6] (lineto)
G01 X [1841*#3+#5] Y [3651*#3+#6] (lineto)
(symbol extents: X = 189 to 1841, Y = 3 to 3651)
(symbol advance: X = 2031, Y = 0)
(start of symbol 0x2F)
(starting X offset: 2031)
G00 Z [#1+#7]
G00 X [3742*#3+#5] Y [3878*#3+#6] (moveto)
G01 Z [0-#2+#7] F#4
G01 X [4190*#3+#5] Y [3878*#3+#6] (lineto)
G01 X [2668*#3+#5] Y [-111*#3+#6] (lineto)
G01 X [2220*#3+#5] Y [-111*#3+#6] (lineto)
G01 X [3742*#3+#5] Y [3878*#3+#6] (lineto)
(symbol extents: X = 2220 to 4190, Y = -111 to 3878)
(symbol advance: X = 2348, Y = 0)
(start of symbol 1)
(starting X offset: 4379)
G00 Z [#1+#7]
G00 X [5034*#3+#5] Y [0*#3+#6] (moveto)
G01 Z [0-#2+#7] F#4
G01 X [5034*#3+#5] Y [2807*#3+#6] (lineto)
G01 X [4568*#3+#5] Y [2807*#3+#6] (lineto)
G01 X [4568*#3+#5] Y [3191*#3+#6] (lineto)
G5.1 X[4945*#3+#5] Y[3341*#3+#6] I[198*#3] J[24*#3]
G5.1 X[5202*#3+#5] Y[3648*#3+#6] I[179*#3] J[127*#3]
G01 X [5586*#3+#5] Y [3648*#3+#6] (lineto)
G01 X [5586*#3+#5] Y [0*#3+#6] (lineto)
G01 X [5034*#3+#5] Y [0*#3+#6] (lineto)
(symbol extents: X = 4568 to 5586, Y = 0 to 3648)
(symbol advance: X = 1396, Y = 0)
(start of symbol 6)
(starting X offset: 5775)
G00 Z [#1+#7]
G00 X [7049*#3+#5] Y [2743*#3+#6] (moveto)
G01 Z [0-#2+#7] F#4
G01 X [7049*#3+#5] Y [2833*#3+#6] (lineto)
G5.1 X[6978*#3+#5] Y[3059*#3+#6] I[0*#3] J[134*#3]
G5.1 X[6776*#3+#5] Y[3151*#3+#6] I[-71*#3] J[92*#3]
G5.1 X[6573*#3+#5] Y[3059*#3+#6] I[-131*#3] J[0*#3]
G5.1 X[6502*#3+#5] Y[2833*#3+#6] I[-71*#3] J[-92*#3]
G01 X [6502*#3+#5] Y [2106*#3+#6] (lineto)
G5.1 X[6918*#3+#5] Y[2275*#3+#6] I[189*#3] J[169*#3]
G5.1 X[7462*#3+#5] Y[2022*#3+#6] I[364*#3] J[0*#3]
G5.1 X[7622*#3+#5] Y[1408*#3+#6] I[160*#3] J[-221*#3]
G01 X [7622*#3+#5] Y [783*#3+#6] (lineto)
G01 X [7619*#3+#5] Y [783*#3+#6] (lineto)
G5.1 X[7368*#3+#5] Y[197*#3+#6] I[-17*#3] J[-350*#3]
G5.1 X[6793*#3+#5] Y[-38*#3+#6] I[-234*#3] J[-235*#3]
G5.1 X[6194*#3+#5] Y[221*#3+#6] I[-363*#3] J[0*#3]
G5.1 X[5964*#3+#5] Y[832*#3+#6] I[-230*#3] J[250*#3]
G01 X [5964*#3+#5] Y [2822*#3+#6] (lineto)
G5.1 X[6093*#3+#5] Y[3304*#3+#6] I[0*#3] J[267*#3]
G5.1 X[6462*#3+#5] Y[3625*#3+#6] I[130*#3] J[216*#3]
G5.1 X[6793*#3+#5] Y[3695*#3+#6] I[151*#3] J[70*#3]
G5.1 X[7392*#3+#5] Y[3433*#3+#6] I[361*#3] J[0*#3]
G5.1 X[7622*#3+#5] Y[2822*#3+#6] I[230*#3] J[-250*#3]
G01 X [7622*#3+#5] Y [2743*#3+#6] (lineto)
G01 X [7049*#3+#5] Y [2743*#3+#6] (lineto)
G00 Z [#1+#7]
G00 X [6505*#3+#5] Y [841*#3+#6] (moveto)
G01 Z [0-#2+#7] F#4
G5.1 X[6572*#3+#5] Y[620*#3+#6] I[0*#3] J[-134*#3]
G5.1 X[6776*#3+#5] Y[524*#3+#6] I[73*#3] J[-96*#3]
G5.1 X[6979*#3+#5] Y[620*#3+#6] I[131*#3] J[0*#3]
G5.1 X[7049*#3+#5] Y[841*#3+#6] I[70*#3] J[87*#3]
G01 X [7049*#3+#5] Y [1516*#3+#6] (lineto)
G5.1 X[6933*#3+#5] Y[1777*#3+#6] I[0*#3] J[157*#3]
G5.1 X[6779*#3+#5] Y[1827*#3+#6] I[-55*#3] J[50*#3]
G5.1 X[6563*#3+#5] Y[1713*#3+#6] I[-143*#3] J[0*#3]
G5.1 X[6505*#3+#5] Y[1507*#3+#6] I[-58*#3] J[-93*#3]
G01 X [6505*#3+#5] Y [841*#3+#6] (lineto)
(symbol extents: X = 5964 to 7622, Y = 783 to 2833)
(symbol advance: X = 2036, Y = 0)
(final X offset: 7811)
(overall extents: X = 189 to 7622, Y = -111 to 3878)
G0 Z [#1+#7]
M9 (stop coolant)
M5 (stop spindle)
G30 Z [#1+#7] (move in Z only to preset G30)
M30 (end program)
You should be using G54. G53 is machine coordinates. In the conversational screen, type in G54 instead of G53. And of course set your X, Y and Z zeros.
I tried G53 in the PP simulator and got the same error as you.
Perfect, Worked, I wasn't seeing the forest through the trees
Thank you!!!!!!!!!!!
AW
Playing around with it a little more, you can't use G53 in these tabs at all. When G53 is used in gcode, it must have a G0 or G1 on the same line, such as...
G53 G0 X0 Y0 Z0
That is called NON-MODAL. Meaning, you can just set it once, you have to have it on the line of code.
But that isn't how these tabs work. They do a G54 once and then follow that with a sequence of G0 and G1 commands to make the cuts. That is why you get errors with G53.
https://www.tormach.com/g53.html
G53 is used rarely, for something like moving the table and head to a particular spot. I guess some machines use it to return the machine to the home (reference) position, which works with the PCNC as well. But we normally just use G30 to move the head up to a convenient place to change tools.
