2” facemill recomendations - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 81 to 87 of 87
Thread: 2” facemill recomendations
  1. #81
    Default Re: 2” facemill recomendations
    Quote Originally Posted by TurboStep View Post
    Yes I was! A lot of the TTS holders I see from china don't have a ground mating surface; this one did, so I felt comfortable getting one. Not super cheap, but I'm from europe, so it's still better than importing it from america. I also got an ER20 holder from the same seller to test out, as well as some ER20 collets from different sellers to compare the runout.
    Which shell mill were you looking at?
    I was looking at one of these: https://www.aliexpress.com/item/3283...3e2e4c4dv2gJgl
    I'm a fool though; I bought the 80 mm 5T version not realising the arbor is 27 mm lol
  2. #82
    Quote Originally Posted by kstrauss View Post
    I use both daily for aluminum on my 770 with two SEHT inserts (the same insert as the SuperFly) and get an excellent finish.
    Why do you use only two?
  3. #83
    Member kstrauss's Avatar
    Apr 2013
    In my experience a 770 doesn't have enough spindle power to run 4 inserts plus with two a stupid mistake is less expensive (yes, we all make them!). With a 4-tooth head it is perfectly balanced with only two. I mostly use the head to take a light skim to ensure that stock is flat prior to anything else so MRR is not important. I frequently set the resultant surface as Z-zero so no reason to use the Haimer.
  4. #84
    I see. Should be alright from my end; I've got 1.8 kW to work with
  5. #85
    Mar 2010
    UK
    I have read with interest comments regarding using face mills over the superfly. I also have a 770. The main reason to using a FM is balance. Any 770 owners who have accidentally started their mill at high speed with a Superfly fitted will know what I am talking about !!!!
    I bought two sizes of FM on ebay at low cost K12/63-22-4T which uses the same inserts as the Superfly. The other BAP400R-50-22-4F Face cutter.
    The arbor for the later was made from a Tormach TTS blank. The larger arbor as machined from 50mm dia EN24 steel ( don't know what the US equivalent is)
    My aim was to keep the stick out to a minimum. Depth of the larger arbor is 14mm, the other 16mm.
    I have 2 inserts fitted on the larger and kept 4 inserts on the 50mm FM . I have not tried these yet, but see no reason that they will not perform as well as the Superfly.
    I am not using the mill for production so I am unlikely to take a depth of cut that would challenge the motor power. Both cutters can run at high speed with no vibration.
    Attached Thumbnails Attached Thumbnails 2” facemill recomendations-img_3806-jpg   2” facemill recomendations-img_3807-jpg
  6. #86
    Apr 2013
    They look nice and I'm sure that they will work well. The only likely problem is if the insert pockets are poorly positioned and one insert is lower than the other; you can always use a single insert with minimal vibration due to the mass of the head.
    I took the somewhat cheaper approach of purchasing a Chinese 3/4-inch straight shank arbour and machining the TTS locating groove around the shank.
  7. #87
    Mar 2010
    UK
    I did check the two inserts that I fitted for height and were within 0.0005" Don't know how close they should be. I dare say if I tried different insert faces or use the other two fittings I might improve this.
    The 50 mm FM seems of low quality I had to remove sharp edges and clean up poorly machined faces with a diamond file. Laying the FM on a flat surface it rocked. I changed one of the 4 inserts for another and made an improvement. Will check this properly later on. Buyers should be aware that there could be accuracy issues not easy to rectify.
    I will try the large FM with 1 insert in also, next time I have some alloy that needs facing.
