the ATC isn't going to the load position...? When I click on pathpilot in the ATC go to load position, all I hear is air coming out of the brass bleeder valves..? I've taken the valve apart and with a little air operated the ATC. So I'm not sure if the solenoid isn't working the plunger tube at transfers the air.?
