Nice. Good to see you making long term plans. They can be the best medicine. Have been for me with an aortic valve from a pig and no prostate gland whatsoever.
I mentioned earlier I had ordered a Haas VF3 and a ST10 lathe.
Well, the lathe is still a go but I have changer the order for the mill.
I canceled the VF3 and instead I’m going to get 2 DT1 Mills.
I changed my order because the parts o make are small, and I know me. If I have a big machine I’ll take in big work.
I mentioned before that I make running gear for remote control race boats and the parts for those are pretty small. Actually, with a couple of exceptions, if I can’t hold 6 parts in one hand then they are too big for me.
The DT1’s are cool. The have 15,000 RPM spindles, they rapid at 2500 IPM, they change tools in 1.8 seconds chip to chip, they’ll rigid tap 8-32 and 10-32 holes at 5,000 RPM.
I don’t get my building till February 1st so now I have a little breathing room so I can take an RV trip in January. Both of my sons moved to the Boise area in Idaho this year so now I have a little time to go see where the moved to.
I won’t be moving there. My oldest son sent me pictures of 8 inches of fresh snow on the ground and I “LIVE” in shorts and tee shirts. I haven’t worn long pants in 15 years and I don’t intend to start any time soon. Besides, Boise is too high for me.
I spent Christmas with my brother at 2,700 feet and after 5 days with my rebuilt heart at that altitude, I was having difficulty just breathing. So living in Boise is out for me.
I’ll keep you posted as to the progress of SEEBOLD MOTOR SPORTS.
Those DT1 mills are quick.
You are going to be a busy guy.
to lazy to chase arrows
Sounds good, Steve.
Look forward to seeing the plans come in as planned. Those machines are designed for speed. No doubt about that.
Lee
Very nice, I envy you :-) I wish I had space for ST10 and one or two VFs.
Dennis
Interesting that you're going for the DT1. In your original thread about this I asked why you chose a VF3 over the DT1 and ... you didn't even respond to the question.
http://www.cnczone.com/forums/tormac...ml#post2129130
Best of luck with you're expanding endeavor.
I did consider the DT1 and the TMs some as well before I ordered the MM. It came down to smaller tooling and more money were the main detractors and not requiring such high speed for the DT1's. Either one of those would have still worked very well for us, but then I consider the MM a perfect fit too.
Lee
I apologize for not replying to your question. I decided to go with the DT1’s because in the space required for a VF-3, I can almost fit 2 DT1’s and the DT1’s are way faster than the VF-3.
Another reason I went with the DT1’s is if I had taken the VF-3, knowing me, I would start looking for larger aerospace work and I don’t want to work that hard any more.
Like I said earlier, if I can’t hold a half dozen parts in one hand, they’re too big for me. Plus the paperwork required in the aerospace industry is a real pain in the a$$.
I sold a medical device that I have been working on for the last 10 years and now I have the money to pay cash for all the machinery and I’m probably going to buy a building to put it all in as well.
I had a TM-1 when I had my shop. I have told my wife if I had it to over again, I would have taken some of the money I got when I sold my FADAL, paid off my Haas and brought it home. It was a way better machine than my Tormach.
Don’t get me wrong, I love my Tormach.
The biggest reason I went back to Haas is the way I was treated when I had to send my TM-1 back.
I owed a little over $14,000.00 when I sent it back, Haas took it back and sold it for $22,000.00. They took $2,000.00 off the top, paid off my loan and sent me almost $6,000.00.
Had that been a bank, they would have auctioned off my machine gfor what ever they could get and come after me for the difference.
Plus, as I have said in a he past, if you run a Haas the way they are designed to be run, you can’t beatem’.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
Haas machines use linear ball rails which are not as rigid as sliding boxed ways. Not that you cannot be productive cutting steel, you just have to take a different approach. Lighter cuts at higher speed instead of heavy cuts at lower speed. Modern CAM software makes this easier than it used to be.
