Issues Machining plasma cut steel and large chamfers
Very new to CNC and machining and still have a lot to learn. I have been attempting to machine a 3/16" deep 45 degree chamfer in 3/8" thick steel plate that was cut into an 8 inch diameter disc on the plasma. I am attempting to chamfer around the entire edge.
I am wondering how people account for the hardened edges from the plasma? Also what might be the best way to go about this operation? I have found a recipe that works but does not seam ideal and i believe it can be much approved upon as im just starting to understand basic speeds and feeds. I have been thrown into the fire and told to use what we have to figure it out. I have been using a 1/4 inch 5 flute endmill in a ramping toolpath stepping down 3 times and moving outward as cutter ramps down. I then come back with a 45 degree .391 max depth cut index-able chamfer mill in a single pass to finish chamfer. I have produced okay parts but believe my speeds and feeds are off and I can cut down on tool wear and cycle time(takes about 12 minutes currently) with a better recipe and tool paths. The edges from the plasma seem to make things tricky as well. I am looking for any input and advice to help and keep me on the right track. As I do not have much experience. here is a link to the tool https://www.mscdirect.com/product/details/00306514
Re: Issues Machining plasma cut steel and large chamfers
Also very new to CNC, so take this with a grain of salt...
This may be a situation where conventional tool path (instead of climb milling) may be appropriate. If you get under the hardened layer it will probably cut better and the tool last longer. Consider a rather wide WOC and cut the perimeter on first to get under and rid of the hardened layer. Maybe a slow pass with slow SFM and kind of treat it like a slotting operation. After that, you can step up and in using climb milling and finish with your chamfer tool at more appropriate speeds/feeds. You might also consider using a larger end mill, preferably a stubby one with a short flute length so it doesn't deflect as it bangs through the crust.
I'm sure someone more experienced will be able to provide better or more comprehensive advice.
If you have slag knock it down with a grinder or sanding wheel. Also trying taking a 2 tool approach. Use a stubby carbide or toroidal cutter to cut the bulk of the material out and finish it up with the chamfer tool. Chamfer tools are expensive and if you want a nice finish save if for the last little bit that way you can ensure numerous parts with a clean finish. Also if time is important I have found that a stubby carbide endmill runs a little faster then the toroidal but the toroidal was cheaper.
