Video RAPIDTURN VIDEOS - Page 2
Page 2 of 17 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 195
Thread: RAPIDTURN VIDEOS
  1. #13
    Sep 2016
    Default Re: RAPIDTURN VIDEOS
    Hi All,
    Here's a few from my youtube channel.
    -Jake
  2. #14
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    Just an update Keen may have some flooding to deal with today
    <img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
    Being Disabled is OK CNC is For fuN
  3. #15
    Feb 2007
    New Zealand
    Quote Originally Posted by buystufmakestuf View Post
    Hi All,
    -Jake
    Thanks for posting Jake!
    I had already stumbled on to your videos and found them very useful...Cheers!
    Very high quality filming by the way.....
    keen
  4. #16
    Feb 2007
    New Zealand
    Quote Originally Posted by daniellyall View Post
    I know! ....whats going on!......Earthquake...and now a flooded workshop floor.......
  5. #17
    Sep 2009
    New Zealand
    Yer A snow next
  6. #18
    Feb 2007
    New Zealand
    I am getting there....here is part 3:
    Cheers Keen
  7. #19
    Member kstrauss's Avatar
    Apr 2013
    Attaching a tool platform using the spindle bolts together with bolts at the back of the head looks like a great plan to get better rigidity and more room for additional tools. Adding two tapered dowel pins should allow a readily re-installed setup with reasonably precise offsets. It is much nicer than my approach of using two split rings around the spindle housing. I'm eagerly looking forward to following your progress!
    The PathPilot interface only appears to support two-axis offsets and you need three-axis offsets to employ gang tooling. Have you any thoughts that you are willing to share regarding configuring offsets for gang tooling?
  8. #20
    Feb 2007
    New Zealand
    Quote Originally Posted by kstrauss View Post
    Yes I have checked that out prior to starting - no major problems there. - I hope to cover that subject in a video soon.
    Cheers Keen
  9. #21
    Feb 2007
    New Zealand
    Hi Guys
    Hey thanks for your Earthquake concerns!...most appreciated!
    Here is part 4: Cheers Keen
  10. #22
    Member tmarks11's Avatar
    Jul 2004
    nice! That toolholder bracket you built looks awesome. You should send some pictures of it to Tormach as a suggestion for a future product.
    One question about your plan to slide the rapid turn down to the left- how much further to the left will the cutting tool traverse on the table? Will that new position allow cutting all the way to the chuck jaws?
    Tim
    Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
  11. #23
    Feb 2007
    New Zealand
    Quote Originally Posted by tmarks11 View Post
    Hi Tim - Yes the headstock current max position left is wasting a lot of the X travel. It is only there because of the T slot limitations.
    Cheers Keen
  12. #24
    Feb 2007
    New Zealand
    Hi Guys.
    Part 5 - Cheers Keen
RAPIDTURN VIDEOS
RAPIDTURN VIDEOS
RAPIDTURN VIDEOS
