Wood is for sheds don't make that mistake it will not make you happy. these machines are very heavy if you are worried about budget check your local welding shops they should have no problem at all making a heavy duty stand. i built mine but it still cost me 650 for materials and some bending work. Mine is way over kill so I will guess you can have a shop do one around 400-600 out of tubing with a top plate just don't forget to add leveling adjusters.
