Spring Loaded Engraving Tool - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: Spring Loaded Engraving Tool
  1. #13
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Spring Loaded Engraving Tool
    Another way to engrave a non-flat stock is to use a program like Autoleveller (Autoleveller | CNC workpiece levelling). It probes the stock surface and then adjusts the input G-code for the height variations. This method gives you precise cutting depth that does not vary with the RPM or the feed speed.
  2. #14
    Apr 2011
    That autoleveller software looks pretty interesting, would be useful for surfaces like PCBs for sure.
    Terry
  3. #15
    *Registered User* cnc2bman's Avatar
    Dec 2018
    These spring loaded homemade engraving tools can be very useful, check this one out:
  4. #16
    Apr 2011
    I checked the autoleveller site, it says it works with Mach 3 and LinuxCNC. Has anyone tried it with Pathpilot yet?
    Terry
  5. #17
    Nov 2012
    Quote Originally Posted by MFchief View Post
    Terry
    No one seemed to mention PathPilot on the Autoleveller forum, you should probably ask that question there. In principle, you should be able to make it work, as long as PathPilot supports a probing move (such as G31 in Mach3) and a file write command (such as M40/M41 in Mach3).
  6. #18
    Apr 2011
    Thanks, I will check out the forum, or I may just download the free version first ant give it a try LoL
    Terry
