And using a simple tap, with a simple, inexpensive hand-tapping fixture, will be faster, cheaper, and at least as good as using a mill or lathe - probably 15-20 seconds per hole.
Regards,
Ray L.
Thank you for the great advice, the reason I am worried about loosing steps is because I was trying to mill things on the xcarve and lost tons of steps and the entire machine and projects I was trying to do because a failure, luckily I was using scrap material from a metal shop that he sold me for pennies becuase it was remnants that were going to be thrown away. But if I spend clost to 10 grand or more on a machine I dont want to EVER miss a step, even if my gcode is not perfect (which I am letting fusion 360 generate for me, since I am not yet savy enough to program my own gcode yet).
I am looking at the pulsar as another poster suggested but the only thing I worry about with that machine is it does not have the same following or community support like the tormach has ... or does it? If I loose a step and a metal disk gets jacked up I might just loose my sh*t lol, even if my code is not flawless I dont want to loose steps.
That pin on the bottom left is for power supply so the tolerances dont have to be tight at all, some of the other parts I have will have to have much greater tolerances as they are optical components.
We were all where you are at one point. For me I built my first machine from an X3 mill which is 20x more ridged as your vcarve. The Tormach is easily 5-10 times more ridged than the X3. You are completely wasting your time worrying about losing steps. Completely. 100%. If the V carve was an easy bake oven and you were using it in a manor other than intended (on metal) then the Tormach is a household oven. Your stressing over digital vs analog dials. It doesn't matter. Out of all the Tormach users do you hear any of them batching about parts ruined due to lost steps? I never saw one of my steps lost. It's basically only if u CRASH and are too flustered to reset and check your offset or trying to bury a 2" end mill that you could ever lose steps. You will HEAR them because you just crashed into the part which is what caused them to be 'lost'.
Ignore the steps. You abuse any machine you will have issues. Watch a few videos of tormach hogging metal. Anyone commenting "OMG I saw a lost step!" no. Steps don't 'get lost' the machine just doesn't know you crashed. Literally just check your zero after crash and it makes little difference.
Sent from my SM-G935V using Tapatalk
@akmetal I feel you have a completely wrong idea about cnc milling. You will crash and scrap lots of parts no matter what machine u buy. If your g-code is faulty the same might happen. You sound like you expect that the machine will just make the parts exactly like you design them in solidworks but there's a lot more to it.
WOT is right. If you overload a stepper based machine (drive the cutter into a vise jaw, try a 2-inch DoC or whatever other stupid thing we all do) you will hear the machine straining and you'll probably "lose steps". On a servo machine you will have the same problem; the only difference is a fault light may come one. Regardless, both machines will have ruined your part. If you're unsure about "lost steps" then recheck your zeros after you've crashed and replaced the ruined cutter.
If your stock and cutters are too valuable to make a mistake you're in the wrong trade/hobby. Expect to make each new part twice and rejoice if you get everything perfect the first try. On any machine!
No worries about that with Tormach, as Brian and Ken said. No comparison between X-Carve and Tormach. X-carve is meant for low-precision engraving in soft materials. Tormach is meant for hogging (relatively speaking**) through solid steel.
They have a very active user forum too:
http://www.cnczone.com/forums/novakon-systems/
The reason to go for servo instead of steppers is speed; the servo machines will rapid at 4-10x the speed of Tormach. Which can be important if you are running 24/7 production for weeks at a time cutting larger pieces. Does that describe you? If not, no reason to shell out an extra $3000, spend the money on tooling instead (easy to do).
** relative to x-carve. Not relative to a commercial VMC.
Tim
Tormach 1100-3 mill, Grizzly G0709 lathe, PM935 mill, SolidWorks, HSMWorks.
My PCNC 1100 is 5 1/2 years old, and I can do +/-.001 work on it ALL DAY LONG and I have never used the tool table in Mach III. I do all my tool length offsets from the offset page of Mach III and I have run jobs with as many as 9 tools.
Yes, it takes longer to do stuff on my Tormach than it does on a good VMC, BUT, my Tormach didn't cost anywhere close to $75,000.00.
I'm getting ready to start a 40 piece job that someone with a VMC would kill me on, but I work in my garage "AT HOME" and I'm having fun doing it.
I'm 72 years old now, so I no longer do machine work to make a lot of money, (been there, done that) I do it for something to do in my retirement.
I watched my dad just sit and waste away after he retired and I promised myself and my wife that I wouldn't do that.
You have fallen for what is undoubtedly the Number 1 MOST common bit of MISINFORMATION that CNC amateurs fall for: The belief that stepper motors are somehow inherently unreliable, and will always randomly lose steps. THIS IS A FLAT_OUT WRONG! Literally millions of stepper-based machines are used in very high precision, very high reliability applications every single day all around the world. The ONLY way a stepper system will EVER lose steps is if it is either poorly designed (which is nearly always the case for home-built CNC machines), or it is operated beyond its capabilities. Under either of those conditions, a servo-based machine will also fail. A properly designed, properly operated stepper system will NEVER lose steps. That is a cold, hard FACT. There will be ZERO difference in accuracy, repeatability or precision between a properly design stepper-driven machine and a corresponding DC servo or AC servo driven machine. ZERO! The servo driven machines will almost certainly provide faster feed rates, and they will be quieter, but that is about it.
Regards,
Ray L.
Thank you guys again for the great information, part of it is if I can get a higher end part like a AC brushless motor for a machine I will likely only buy once why not have the better part ...
Would you say the pulsar is just as good if not better than the tormach?
1100 Personal CNC Mill | Tormach Has Affordable CNC Milling Machines
Pulsar (NOVAKON) – Novakon
Looks like they are about the same price, are there draw backs to the pulsar?
Looks like the same list of coming soon options I saw two years ago when I decided not to wait for the community to manufacture parts for the machine to be comparable.
Automatic Tool Changer (ATC)- Torus PRO – Novakon (NOTE THE DATE)
And I looked HARD at adding their big boy next to my Tormach in the garage, but ended up deciding to fork the money for a Haas and a shop. Lot more overhead, but a LOT more parts get made without me standing there babysitting. 2 years with zero Gib adjustments :-p
If that had been ready two years ago, I would probably still be in my garage. Pluses and minuses to having a nice big shop and 3 phase, but $3,500 a month for the last two years adds up... to $84K. Not sure I made an extra $84K by having the shop vs my garage LOL.
At $20K though with ToolChanger and servos on a pulsar it's just too close to a 2005 Mini Mill
No. Have to add power draw bar, and ATC to both
Everything is picked Ala carte you have to build a full quote to see what it costs (actually able to even turn on) suited similar or the way you need it. For example the 770 looks so cheap I can pull enough cash out of a single arm to buy it... Then add a computer so it can operate... Jog handle, monitor, cables, power draw bar, low pressure switch, ATC, stand, etc etc etc. It ain't quite as cheap anymore.
I sold my tormach after 2 years for over 75% of what I paid. Basically rented it for $200 a month. Not too shabby considering it made roughly 15,000-25,000 parts.
Automatic tool changer. And yes.
