Hi All,
Thanks for all the feed back, made a few changes after going and buying an air compressor.
(a) Now running fogbuster with coolant
(b) Clearing chips with constant hi pressure air
(c) changed code to 8000 rpm and f48 ipm and chip load sitting at 0.002.
Managed to break the other (second last) 1/4 cutter, it broke along the centre section as it enters the left square (i.e. not on a plunge .... the machine sounds like it was kind of laboring during all the cuts (however not sure as to the noise it should make as I have only cut plastic to this point). It wasn't what I would call really uncomfortable sound .... if that makes any sense.
I have included a photo....
Starting to think maybe the cutters are the wrong ones ???
I only have one more 1/4 cutter which is a ruffer .... happy to take on some more input before I break this one
as I will need to order some more in once this one is gone as you can't buy them locally.
Happy to post code if that helps.
Cheers,
Adrian
